Why is my display reading 1H and flashing occasionally?
I have. Whirlpool Gold Quiet Partner 3
Model # GU2400XTPQ7
Age unknown for sure
Ran a regular cycle like always last night, this evening when I come home the display is reading 1H and blinking every once and a while. When I tell it to cancel, it starts running a two minute cycle but doesn’t sound like it’s producing any water. I ran a regular cycle to try to clear it. Dishes were wet by the end, so it can produce water, but the 1H came right back after the cycle.
How doi do I fix this, or is the machine just toast?
Update (03/11/2020)
Model # GU2400XTPQ7
New update:
I did the sani-rinse/heated dry combo and it worked temporarily.
it gave me the code d3, and did a countdown from 7, flipping through different settings until it turned off. However about 7 hours later it randomly kicked on for about 1 minute with nothing on the display and just now the 1H was back on the display even though no one has touched it.
Bu iyi bir soru mu?
1 Yorum
Hi @kallile ,
Check if there is a "tech sheet" taped behind the dishwasher's kickboard (toe panel?)
If there is it may help you to narrow down to what the problem may be.
jayeff tarafından
