Display has no backlight or blank dark screen
My backlight stoped working and i found out that the iphone 3g has no 6r8 coil so do i change the lcd ?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
simple answer is yes, if you are sure that it isn't a loose connection, dirt or damage. I'd try a hard reset..press home and power together for 10 seconds, the apple should appear then allow to reboot...far cheaper and usually works. The other thing to try if this has happened after you have opened the phone is to take the motherboard back off the battery for an hour or 2 then replace. New LCD is the last resort .
Bu yanıt yardımcı oldu mu?
i guess it is because of the water because i gave it to my dad and when i got it back there was some drops of water on the iphone
and i even took out the motherboard to see if there was a 6r8 coil so i guess i did the two options so i have no choice but to buy a new LCD.
I'd still try a reset.. Did you think maybe it's a power problem? Is there signs water was inside phone? The first thing to stop working is battery/dock, LCD is usually ok once you've cleaned the connections
every thing works fine only the backlight
i did the reset by pressing the home and power button and the apple logo appeared but it did all that without a backlight
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,106
