Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6s. Available in Silver, Space Grey, Gold, or Rose Gold with 16/64 GB storage options. Model A1662 and A1723.
922 Soru Tümünü görüntüle
Can I use lithium ion battery soldered to pins
Switching out batteries last night and I one caught fire. Long story. I cannot order parts at this time so I have a iPhone se and a 2000mah battery that isnt a replacement battery but it will fit in the phone. I’m wondering if it’s possible to solder wires directly to the battery connector and use it to power the phone.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Short answer: Yes, it is possible. There are cables for testing iPhones that literally just hook power and ground to the connector. However, the battery does have ICs in it that communicate with the phone about things like battery percentage. Because of this, I would say your best bet if the phone is to be used long term would be to try and desolder the circuit from the exploded battery and connect it to the working one. Then it can be connected like normal.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
Also, the phone will reboot every couple of minutes if you do not include the battery data (ie power and ground only)
tarafından
Yorum Ekle
Yanıtını ekle
Brayden S sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 32
