Ana içeriğe geç
A lawn mower made by the American Company Toro
119 Soru Tümünü görüntüle
Spitting Oil out Exhuast when starting
Went to start my mower today and when I pull the chord to start it, it just knocks and a puff of white smoke comes out. I also realized that there is oil, a good amount, dripping out of the exhuast. It's been sitting right side up, never turned over, so I'm at loss for what to do. Any info anyone has would be great.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
I would say you flipped it and that’s why you’re getting that but it could be a gasket try checking the gas for oil
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Its sat for the winter and I haven't touched it. There isn't oil in the gas. I just put gas in it for the first time this spring. Didnt want gas sitting in it while not being used.
tarafından
Yorum Ekle
Most likely is that you are overfilling the oil. Second would be leaking piston rings.
Puan 0
2 Yorum:
I haven't put oil in it this year since the spring has just started. I checked it and it's at normal level. How would I check the piston rings?
tarafından
Of course the piston rings are around the pistons and the the engine would have to be torn down to inspect them. This usually does not happen until a mower is several years old.
tarafından
Yorum Ekle
Yanıtını ekle
Clif sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 15
Her zaman: 113
