Ana içeriğe geç
Sometimes won't power on, only has black screen & power light
Hi! I've got a 15" aluminum Pro that is not behaving. Typically when powered on, the optical makes its startup noise, the screen stays black, and the sleep light glows. The chime noise does NOT sound. Occasionally when I try various things such as reseating/changing the RAM, pulling the battery, etc., I'm able to get it to power on, screen and chime and all, and to act perfectly. When it does this it stays working for most of a day, but just when I think it's "fixed", it goes back to black screen/glowing sleep light mode. I've ruled out AC, battery, memory, and the memory slots.
My first thought is that this machine may have the Nvidia GPU issue, because it is within the range of machines that could potentially have the issue, and that issue is becoming more prevalent in general. However, I've dealt with many of those machines, and they usually do chime and act as if they are working, aside from the black screen, whereas this one goes into the odd mode I've described above, with no chime. There is no external video when it's in this mode, but external video works fine when the machine is working.
Does anyone have any ideas, and does anyone have an opinion as to whether or not this could still be the Nvidia issue? My next step is to replace the DC-in board, but if it seems likely to be the Nvidia issue I'll take it to the Apple store instead (because it's within the 4 year window, and they would replace the board if it qualifies).
Thanks!
John
Bu iyi bir soru mu?
Puan 11
14 Yorum
Have you pulled out the optical drive? No chime means that your machine is not passing POST hardware tests. Try removing optical drive.
tarafından
When you say that the machine works normally then goes back to sleep mode, do you mean after a reboot or during operation?
tarafından
It didn't make a difference. I've seen a zillion machines with bad or no opticals that would still boot...have you seen a bad optical stop a Pro from booting?
tarafından
I believe it's generally been when it's first powering on or rebooting. But it may have done it once when it was already on...I don't recall though.
tarafından
I have never ran into this problem myself. Just a recommendation since you have removed/tested everything else.
tarafından
9 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
It looks like the test may be available on Torrents. Will let you know if I can get a successful download. This would be a great time saving tool if we can get it. http://www.torrentreactor.net/search.php...
Bu yanıt yardımcı oldu mu?
Puan 4
11 Yorum:
sir if the laptop is not turning on then how test will run on this ?
tarafından
SIMRAN with all do respect, at times the computer will run. rdklinc stated in his question at times it will run for most of a day. Furthermore for most Apple service centers the computer will need to be running to run the test and approve of the repair. Interestingly, it appears, the program writes it's results to the hard drive on the computer being tested as well as to the device being used to test it. In other words it is visible how many times the test has been run and the results of those tests when running the program.
tarafından
I've seen Apple do the testing many times (although I haven't paid as much attention as I wish I had) but I can definitely say that the test does run from the diagnostic drive even when the screen is black. In other words, a Pro with the Nvidia defect still has enough basic functionality to write to the diagnostic drive, after which the Apple employee looks at the test results on another machine and takes note of whether the GPU has been pronounced dead or not. Like I mentioned, I'm not confident this particular machine has the Nvidia issue, in which case the test likely will not be able to run on the machine, and they will likely pronounce that the computer has some other issue. But we will see, and I'll post what I find out.
tarafından
The place I use for downloads does not have it. Maybe someone else can get it and OldTurkey can put it on his server.
tarafından
Be careful though -- I believe it's a tool that Apple sees as "Apple only", so I'd hate to see anyone get in trouble downloading/using/distributing it....
tarafından
6 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
this is the best way to go there in apple store for checking if this model has Nvidia 8600M GT graphics then they will replace it within the 4 years of purchase of this laptop.
MacBook Pro 15-inch and 17-inch models with NVIDIA GeForce 8600M GT graphics processors
MacBook Pro (17-Inch, 2.4GHz)
MacBook Pro (15-Inch, 2.4/2.2GHz)
MacBook Pro (Early 2008)
These computers were manufactured between approximately May 2007 and September 2008.
Puan 5
1 Yorum:
Sounds like his is in this time frame. Might be a free repair. ;)
tarafından
Yorum Ekle
This is going to be either a bad NVIDIA or GPU solders and needs to be reflowed. I own mobilemactechs.com and I do them all the time for $250.
Puan 1
2 Yorum:
Is that really worthwhile, considering you can buy a new board for $200, and reflows are not reliable and generally fail after a matter of months, at best?
tarafından
You have bga problem, need rework or reballing this bga chip.This solve your problem.
I´m in Spain,www.netcomplanet.com , we have a profesional bga rework machine to do this work,if you need contact us.
Best regards,
Pablo Figueira.
tarafından
Yorum Ekle
We are in Spain and we have a profesional bga rework machine to do this work,if you need contact us.
Best regards,
Pablo Figueira.
Puan 0
Yorum Ekle
Hello. I'm wondering what the final solution was as I'm having the exact same problem.
One addition, I noticed the mac running hot and see some damage to the plastic strip that runs along the hinged side. The damage may have been there previously and I just noticed it, or the machine could have gotten hot enough to melt the edge of the plastic.
I'm not at all technically savvy, but I've been using macs since the beginning. If any answer could be broken down into layperson's terms, that would be fantastic.
Thanks in advance!
MHP
Puan 0
Yorum Ekle
Yanıtını ekle
rdklinc sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 10,542
