Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
20 Soru Tümünü görüntüle
I don't know how much battery is left
My phone’s battery is completely dead, as in it won’t turn on even when connected to power. I think there is still enough energy (more than 25%) left in the battery, so i’m scared to attempt the battery replacement. If I can’t turn my phone on is there a way to drain the remaining energy from the battery?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Have you tried other lighting cables first, just to check if it’s getting a charge at all? The battery will naturally drain, albeit very slowly.
Regarding changing the battery. Yes, not having a full charge is best, but you don’t have to have it fully drained when replacing it. Follow the steps and take your time. As long as you SLOWLY work the adhesive from under the battery, the battery comes right out with absolutely no force.
What I used to do is get a pair of needle nose tweezers and pinch the black tab at the end of the adhesive. Then pull a little of it from under the batter and twirl the tweezers. I’ll grip on a little better and give you more of a handle to work with.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Lucy Hanacek sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 31
