How to get stuck screws on the inside loose?
I am trying to fix the L and R buttons on my 3ds so I can use it as a good gaming system again.
One problem I am having is that the screws on the bottom inside cover. Here is a example picture of the screws I mean.
How would I get the 2 that are stuck lose without breaking the screws or my 3ds cover?
Any tips or ideas will be much appreciated.
Bu iyi bir soru mu?
Are the screws stripped or are they screwed in hard?
Erik Eriksson tarafından
How to Remove a Stripped Screw
Veronique tarafından
@eke0909 I am not sure if they are stripped or just stuck, they probably are striped but I have the other 3ds that I am getting the parts I need from, the screws on that one just seem to be stuck, so tips for both would be very helpful.
aRealCyborg tarafından
@veronique2020 thanks for that page, but it does not help me in this situation since these screws are in a little hole making them really hard to use any of the tricks in that article.
If you have a sharp tip of soldering iron - carefully heat the screw by touching it. (i do not know how deep are these screws). Either way, you need to take a chance!
2 tane daha yorum göster
