Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1046 Soru Tümünü görüntüle
Dropped my original iPhone SE. Display not responding to touch.
About an inch of the screen not responding to touch.
Rest of the screen is fine and there no visible damages to the phone.
Please tell me it's just a cable connector come off loose and I can open and press on these clips to fix it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
That might be the case, otherwise you may need to do a full screen replacement. The screen replacement guide on Ifixit.com will show which cables should be connected and if neither of those suggestions work, it’s a motherboard issue, and not cost effective to repair, in my opinion.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks. Just tried to remove all three cables and connect it back again. Still the same issue. What I don't understand is, everything was working fine before the drop. It should be a mechanical dislodge of some sorts isn't? Can't wrap my head around how a two foot drop might kill a motherboard circuitry.
tarafından
@ncifixnc That was a last resort thought, as far as the mother board, I think the screen replacement will do you just fine, I apologize, I was giving all scenarios.
tarafından
Yorum Ekle
You will have to replace the screen, it has damaged it and there is nothing you can do except change the screen. It can have a hair line crack or damaged it somehow. It had nothing to do with the motherboard. Put a new screen on it and you will be fine. A new screen is less than 30 dollars.
Puan 1
2 Yorum:
I agree with you as well, I just was giving all scenarios, sorry about the confusion :)
tarafından
I understand, I haven't heard of issues with touch on the se from a drop. But if only a small part of the screen won't respond to touch then it's definitely a screen.
tarafından
Yorum Ekle
Yanıtını ekle
ncifixnc sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 129
