Can the HP Touchpad LCD glass screen be removed from the frame?
Can the HP Touchpad LCD glass screen be removed from the frame and replaced with the iPad front glass?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Yes it can!
Bu yanıt yardımcı oldu mu?
How? Not that I do not believe you, but it will help your answer if you let us know.
use a butter knife to pry it loose along the edges. It snaps back into place when finished.
and the iPad front glass snaps right in the HP TouchPad?
A hair dryer or heat gun helps when trying to remove the old glass and tape.
You can also bake the front panel assembly in an oven; 175 F seems to work OK. But then there are more places to burn yourself when it comes out...
In either case, you want to have the front panel detached so that you aren't cooking sensitive electronic components.
I don't know the iPad front glass, but it probably with the HP TouchPad, which has its own digitizer -- I doubt they're pin-for-pin compatible.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,262
