Why does the washer fill with water when it's off? - RESOLVED
washing machine fills the tub with clean water when it’s off.
At a loss here. The water is clean. It’s not coming from the drain hose; it’s elevated correctly.
Brand new inlet valves and supply lines. Pressure is fine. What’s going on?
Update (05/27/2020)
Per the question, the pressure is fine. Its much higher than it would need to be (20 psi) for the valves to operate correctly. Like I said, the inlet valves are new. So are supply lines.
I was, however, able to confirm that the new hot water inlet came defective. I removed the soap dispenser and dried out the inside. Steady stream of water coming in from the hot water inlet valve. Getting a replacement
Bu iyi bir soru mu?
1 Yorum
Hi,
What is the model number of the washer?
Have you tried closing the washer's hot and cold water supply taps (spigot, faucet) one at a time to see which supply is causing the leak?
By inlet valves do you mean the washer's water inlet solenoid valves?
jayeff tarafından
