After installing New HD won't start
After installing a new HD in MBP it's dead. Won't start. Connected to power cable and power light on cable is on but computer will not start. What else can I do now?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Reconnect your top-case to logic board cable.
Bu yanıt yardımcı oldu mu?
Please explain further
It sounds to me like your unit is not getting a power on signal. The most common problem with this when a computer has been worked on the the cable that connects from the top-case to the logic board. See step #10 on this guide: MacBook Pro 15" Core Duo Model A1150 Upper Case Cable Replacement
this could be my problem. The original video I watched talked about prying it up and maybe I separated the "plug" from the board. I'm not really sure as I can't tell from the photos what it's suppose to look like. Should I have seen pins on the bottom of the cable? Did it "plug" into the board or just come in contact?
It's to hard to explain what kind of plug it is ( a rectangle socket) , just push it down with your thumb. If you leaned the keyboard up against the screen it probably pulled on the backside of this plug and lifted it out. It probably has some kapton tape helping to hold it in place.
I may have pulled the whole plug assembly off the motherboard. I only pulled at the yellow tape but maybe due to age the solder separated. Now what do I do?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 383
3 Yorum
Hi, We need some more information to help you.Which MBP do you have? What are the last three numbers of the serial number? What drive did you install and what color light on the power cable? Why did you replace the drive?
rj713 tarafından
Pre Unibody vintage 2006. Last 3: VWW. Installed WD 250 GB Scorpio Blue. Old drive died.
economy10 tarafından
Apple MacBook Pro "Core Duo" 2.0 15" Specs
Identifiers: MacBook Pro - MA464LL/A* - MacBookPro1,1 - A1150 - N/A
mayer tarafından
