Changed battery and now driver's side window won't go down and door lo
Door locks and window on driver's side don't work after I cleaned my battery post
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I doubt it had anything to do with you changing the battery. You need to check the fuses. There is a fuse box under the hood and one inside the car. If those are good I would check and verify that you have no power to the switches. If not and the fuses or breakers are ok I would verify that you have power before the the door. You wire loom on the door hinge can be pinched and break a wire. You will have to test these with a volt meter or test light. And it doesn't matter how the white looks like on the outside it can be broken inside.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 249
