Ana içeriğe geç
Can't find the internal hard drive
I spilled water on my keyboard, now the MacBook Pro A1150 turns on and can't find the HD, but it can boot from the external HD, it works perfectly.
Looking at the interconnection cable of the internal HD seems normal, any suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First keep in mind this is a very old system! So anything you do might break something as the plastics get brittle!
From the sounds of it I would say the HD cable or its connections to the drive are in trouble. What is not very obvious is the drive has two connections on the PATA connector. One for the data ,and the other side for the power. Carefully lifting the drive up you should be able to see if power is even getting to the drive, use a DVM and measure the connection points. If you have power then you either have a bad data side connection of the cable or the drive its self got damaged.
Bu yanıt yardımcı oldu mu?
Puan 3
11 Yorum:
Hi Dan. What I find strange is that water damage may have caused the cable, visually the cable does not present any damage, and you can see that when I turn on the mac the HD is spinning.
tarafından
I just removed the drive and put it on another mac it's working perfectly
tarafından
Do you think it would be the case to remove the motherboard and give it a bath with isopropyl alcohol
tarafından
I would still check both the logic board and cable for corrosion damage, If you don't see any I would replace the cable 15" MacBook Pro Hard Drive/BT/IR Cable, Apple P/N 922-7264
tarafından
Hi Dan. I bought a new cable and replaced it, I still have the same problem, only boot, with external drive.
Today I took the motherboard out and cleaned it with isopropyl alcohol, I set it up again and the same problem, just from boot with an external drive, Ithe system doesn't recognize the internal drive?
I'm tried to find the diagram of the board of the Macbook pro Modelo 1150, to try to understand better this problem.
Here in Brazil the components for the 1150 are very cheap.
Any suggestion
tarafından
6 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Jose Dias sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 130
