Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
The Google Pixel is Google's first flagship phone, released on October 20, 2016. The 5-inch AMOLED display device comes with 32 and 128 GB storage options and is available in three colors; Very Silver, Quite Black, and Really Blue.
95 Soru Tümünü görüntüle
Replacement battery reported "overheat" and won't charge
I replaced an old battery with the one I got from ifixit in my Pixel (original) phone. Now I have a really hard time charging it because, apparently, it’s reported as overheated, although it’s never even warm to the touch. The only way I’ve been able to charge it so far is to put the phone in the freezer and charge without turning the phone on. Once on, it will not take any charge and is stuck on whatever charge it had before turning on. The battery is reported “overheat” pretty much all the time, even when not charging.
I am convinced I ordered the correct battery and did not make any mistakes when replacing it. It seems like a deficient temperature sensor on the battery. Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Well, here are some ideas to that might help those facing the same problem. I can consistently charge the phone when it’s chilled, which is a confirmation of a problem with the battery temperature management. It’s either the temperature sensor/circuitry on the battery that is out of whack, or a charge controller which misinterprets the (correct) data from the sensor, possibly damaged in the process of opening the phone (heat damage). Either way, this can’t be helped easily.
For what it’s worth, the battery did not seem to be OEM, although the same format and appearance, the writing on it was all Chinese, while the original one was in English. There might be some incompatibility between the two.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Vladimir Grabarchuk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 68
