Service battery error on Unibody 2010
Im getting a service battery error, ive tried two new batteries and im still getting it. I have a 2010 Macbook unibody. Model A1342.
in coconut
Current Charge 3259mah @ 65%
Full Charge capacity 5000mah
Design Capacity 6600mah
Cycles 1
Update (06/23/2020)
https://i.ibb.co/fXZWJsh/Screen-Shot-202...
Battery made by Dynapack Was built on 4/20/20
https://i.ibb.co/HhxjQND/Screen-Shot-202...
https://i.ibb.co/1TY86pF/Screen-Shot-202...
https://i.ibb.co/pr4hqg8/Screen-Shot-202...
Heres a pic after its charged to 100%
Bu iyi bir soru mu?
4 Yorum
Who's battery are you using?
Also, it would be helpful to see the CoconutBattery output. Ideally, one with the battery under charge around ~80% with the charger plugged in and a second after the charger was removed for a good 3 minutes.
Post a snapshot of the main app window of each Adding images to an existing question
Dan tarafından
@Walt Berger - What does it look like charging?
Dan tarafından
Im letting battery get down to about 2%, then im gonna fully charge it. Ill get back to ya on how it does charging, make sure i take a screen shot. Thanks for helping.
Walt Berger tarafından
The battery went from 75.3% to 75.8% after 3 charges (cycles). Weird, ill look up logic board and test some things. Stinks love this laptop. Got 2.4ghz Duo, 16gb ram, 500gb SSD. Thing for what I do is perfect.
