2008 Aluminum MacBook not turning on
Hi, I have a 2008 Unibody Macbook that I found the other day in a drawer and I tried to turn it on but there is no signs of life. The magsafe charger doesn't have any light on it and the fans doesn't spin, and the battery indicator has no lights. Although the laptop gets hot around the logic board.
Could it be a dead logic board, if not then how do I resurrect it?
Bu iyi bir soru mu?
Do you know why the system was put into the drawer in the first place?
While it's likely fixable it may cost a bit in parts. Like needing a new battery and MagSafe charger and that's still not addressing the anything else. Consider the costs and the limitations this system has.
I would open the system up inspecting for damage.
Dan tarafından
I left it it in the drawer as I have upgraded to newer Macs, a while back but now since I'm cleaning up my room I was found it back and I'm curious to see if I can revive it.
Yes I have opened up the system and check all of the connections and the logic board but there is no corrosion or anything.
Aidan tarafından
