Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Model No. A1367 / 8, 16, 32, or 64 GB capacity
1320 Soru Tümünü görüntüle
What is the purpose of the spring near the rear camera
The 4th gen. Ipod touch that I am working on repairing has an issue with the spring that is located beside the rear facing camera. It is has been stretch out, and probably should be replaced.
I have been looking for information on what purpose the spring serves as well as for replacement information. I have been unable to find an information regarding this spring. Several sites reference it, but do not tell what is purpose is or if there is a replacement.
Thank you in advance for any information regarding these questions.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
12 Cevap
Filtre ölçütü:
Seçilen Çözüm
You're talking about that tiny baby spring in the corner right? I am not 100% positive of it's function but my best GUESS, judging purely by it's location and proximity to other parts, is that it's used for grounding.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
Without the spring, i noticed that the digitizer screen doesn't work. Does anyone know what size the spring is and where i can get it?
tarafından
Yorum Ekle
I have seen them removed before. I'm not sure what the long term effect is, but the device works without it. If its stretched out, maybe cut it so it still grounds.
However, I believe it's best to avoid damaging it or replacing if possible.
Puan 0
Yorum Ekle
Thanks so much. Now when I connect the screen back together WITHOUT the little spring, there is a very faded screen. You can see it running correctly in the background but can't get a clear pic on screen. Any ideas on where to get a replacement spring or how to fix without the spring. Thanks for your help.
Puan 0
Yorum Ekle
It looks like it grounds to the outside body. The metal plate that attaches to the LCD screen goes against that spring then to the outside metal case. But that's my guess at it.
Puan 0
Yorum Ekle
The Spring is for grounding the digitizer.
Puan 0
Yorum Ekle
What size is the spring, and where i can I possibly get the replacement for it?
Puan 0
Yorum Ekle
i had the same problem with the spring, after removing the screen and replacing it i notice it wasnt there. but i went on and connected my cables and the ipod came on but it doesnt unlock the screen i have to use fast force to where it worked but something isnt right. could it be there spring? not connected well? or not rewrapen my foil over the digitizer? or bad lcd?
Puan 0
Yorum Ekle
I have also lost this spring while knocking out glass shards from the iPod body. After searching for a replacement and not finding one online (and searching the carpet for a solid 45 mins) I came up with a brilliant idea to try a filament from a MR16 bulb. The first I tried was too large and would not fit, but the second I tried worked like a charm and after reassembling device, was successful with no adverse effects. more specifically, i used a Philips Halotone 20w 12v aluminum reflector - model number 409355. this bulb here - http://www.bulbconnection.com/ViewSIMIte...
break it open with caution! they are under pressure and WILL explode, sending glass shards.
hope this helps to those who have lost this spring.
Puan 0
Yorum Ekle
When my friend lost his little spring during a LCD/Digitizer repair it had no color/backlight on his screen so I'm assuming it grounds the digitizer. I'm not really sure if you can find a replacement for it. I've heard of some people having no problems without it, some say any replacements screens they have refuse to work without it.
Puan 0
Yorum Ekle
So I opened my iPod 4 up to replace the screen (I bought it used and I think the screen may have been replaced once already). The spring was missing, not sure if I lost it or if it was already missing. In any case I took about four strands of fine copper wire (from a length of 22 gauge stranded hookup wire) twisted them together tightly, and cut off a segment so that when I dropped it in the spring hole it stuck out about 1/32". The theory was the wire would be flexible but still make a reliable contact from the bottom of the hole to the plate at the top (if that indeed is the spring's purpose). Finished the screen repair and the ipod worked fine. It might've worked fine without the spring/wire, I can't say for sure.
Puan 0
Yorum Ekle
on the little spring.with it my camera dont work. try it. its not a ground.
Puan 0
Yorum Ekle
And i have 2 i pod 4 that work great no bracket on new screens. fixs better. but no camera functions.
Puan 0
Yorum Ekle
Yanıtını ekle
Michael Burgess sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 7,353
