Ana içeriğe geç
Repair guides and support for shredders of paper, credit cards and any other documentation.
33 Soru Tümünü görüntüle
repair shredder won't turn on
My shredder won’t turn on or run in any way. My daughter thinks the oil may have gummed it up. I need to know how much you charge
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
mamabear918 … it sounds like a power supply issue has occurred. the device will need to be opened up and tested for where the voltage enters and then stops to find the issue. It may be an obvious issue once opened i.e, burnt, bulged or split component. a local tech should be able to repair this simple device relatively quickly. many tecs and shops differ on price, but the ballpark is around the same. this repair to me will be around a hundred dollars or less if done locally.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
mamabear918 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 73
