Are the Gps and Lte battery interchangeable
Looking at the parts selection The Apple Watch Series 3 42mm’s Lte battery kit is out of stock but not the GPS version if I buy the GPS version are they interchangeable?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
they look like the same connector, and same voltage, just a slight difference in mah.
But, ill say if you have never worked on one of these before it may not be worth trying to change the battery. Its a very difficult device to work on, even for an experienced technician, and you will most likely break the display/digitizer, and potentially damage some other components. The displays arent cheap either, and at that point youd be better off just buying another one, not to mention that you will lose all the water resistance it has.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 76
