Ana içeriğe geç
Dryer Shuts off and won't restart until cool
So I have a Kenmore 90 series dryer. I recently replaced all of the rollers because they were shot and one roller had completely fallen off. While I was in there I vacuumed all of the dust out of everything. After that repair my dryer will now sometimes stop mid cycle. After stopping, it will not restart for a while until it cools down. This also happens if I open the door mid cycle - it then will not restart until it cools down. I just took it apart again and tested the continuity on the 2 thermostats (one on the exhaust and one on the heating element area) when cold and when hot and they seem to be functioning correctly. I also checked the continuity on the 2 fuses (one next to each thermostat). The motor spins very smoothly and I got most of the dust out of it with the vacuum so I don’t think there is any added friction there. What is my next step to diagnose this dryer? I’m thinking maybe it’s the motor overheating - how would I figure out if that is the issue? Any help would be greatly appreciated. Thank you!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Did you figure out what the problem was by chance? Mine is doing the exact same thing.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It could be the safety switch on the door latch, maybe as the dryer heats up, the switch warps and looses contact, the dryer then acts as if the door were open?
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I'll see if I figure out how to jump it and give it a shot. Thanks
tarafından
Hopefully that will do it, that would be a quick easy fix
tarafından
Yorum Ekle
Yanıtını ekle
Dylan Gottlieb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 583
