Ana içeriğe geç
AC clutch won't engage
5/1989 Toyota 4X4 pickup w/22RE. AC clutch won’t engage. If I run a jumper to the clutch power wire, it works. Multiple wiring diagrams vary considerably and do not show location of AC relay and related electrical components. 10 amp fuse behind glove box is good.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
check you ac fluid level if its to low the clutch wont engage
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
The 10 amp fuse doesn't go to the ac clutch. The first thing you should do is see if it has freon in it. It has pressure switches that would engage the clutch unless there is enough pressure in the system. It could also be a ac relay but my guess is it's low on freon and it's r12 originally and will have to convert to R134A. First have someone put a ac gauge on it and check the pressures.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Geoff McLeod sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 53
Her zaman: 2,140
