Ana içeriğe geç
1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
139 Soru Tümünü görüntüle
MacBook Air - Magsafe Light Stays Green, Battery Not Charging
I have a mid-2012 Macbook Air 11" that has developed a problem where sometimes the magsafe light stays green when plugged in and the battery does not charge. The status in the menu bar is "Power Source: Battery". Other times, usually after an SMC reset, the magsafe light turns orange but the status in the menu bar is "Battery is not charging".
Through copious amounts of googling, I've discovered and tried various remedies: SMC and NVRAM reset, unplugging the battery and draining the caps, even installing a new battery. None of these fixed the problem. My charger tested good and I was able to charge a friend's Macbook Air with it. Trying my friend's charger on my Macbook Air I experienced the same problem as described above.
My thought is that the the DC-in board could be damaged, but I don't know how to test the board. Is there any specific testing I could with a multimeter to check for voltages? Any damage that I should look for if I remove the board to inspect it? Could the problem be on the logic board?
Other than this issue, the computer runs perfectly, although the battery is draining a bit more each time I boot the computer, so I will soon not be able to boot.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
tarafından
Hi Dan, thank you for the reply. I was unable to install CoconutBattery because my battery is down to 1% so I had limited time to be able to take the attached screen shot. I did have a different battery health app installed previously and the details can be seen in the screen shot. I also added the Power screen from System Information. Note the negative Amperage indicating the battery is draining even though the charger is connected.
tarafından
Did you use a metallic tool to disconnet the battery. If so maybe there was a short between the power pins (12v) and the data pins (3.4v) on the battery socket.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Let’s inspect the MagSafe port on your system and the MagSafe charger cable end as well. Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters. You may need a new MagSafe charger make sure you get a REAL Apple unit. The marketplace is now flooded with knockoff’s which will damage your system. Don’t buy off of Amazon or eBay as a good 90% are junk and can damage your system.
Go to an Apple Store or authorized reseller make sure the packaging looks correct or order it online here Apple 45W MagSafe Power Adapter for MacBook Air
Here’s more on the knockoffs:
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
Update (08/01/2020)
Here’s the pinouts
Bu yanıt yardımcı oldu mu?
Puan 0
6 Yorum:
Hi Dan, thank you for the reply. My charger (OEM Apple) is able to charge my friend's Macbook Air, and trying his charger (also OEM) on my computer, I get the same behaviour described in my post. I've also inspected the Magsafe port using a 10X loupe, and cleaned it using 99% isopropyl alcohol, and checked the connector for stuck pins. I did not see any burn marks or carbon buildup, but gave the terminals a scrape with a pin just in case there was any corrosion buildup on the terminals, and the connector's pins return to their proper position after a slight push with a pin.
tarafından
@miguel_sanchez - mmm ... Newish battery which by your output has only had 3 cycles and is in good health. So either the battery has some strange issue or the charging logic is having a problem, yet its charging with 14.6 watts!
Let's do this shut the system down fully, leave the charger plugged in and forget about your system for a full 24hrs. Don't do anything to it, let it sit then lets get another output of where things stand. If you can try to get CoconutBattery installed as I'm more comfortable with its output and trust it.
tarafından
Hi Dan, I left the computer plugged in as you suggested, and I installed Coconut Battery. I added the screenshots to my original post.
Battery level is still at 1%, but now status is "5:47 until full" and this time has not budged in the last 15 minutes. Note the negative amperage again in the Power screen. Magsafe light has remained orange since it was plugged in more than 36 hours ago.
tarafından
Did you have a liquid spill as some point into the keyboard or trackpad?
Lets replace the left I/O board which is were the MagSafe connector is located MacBook Air 11" (Mid 2012) I/O Board and here's the guide MacBook Air 11" Mid 2012 I/O Board Replacement
If that doesn't change anything that only leaves us with the logic board its self.
tarafından
No spills, we're careful about how we use the computer. Will the magsafe light up when the I/O board is defective? Are there any test points on the board that I can check with a multi-meter to confirm that the problem is in the I/O board and not in the logic board? I'd rather know which board is bad before I spend any more money on this computer. I'm handy with tools and basic electronics but I've had a difficult time with this particular issue.
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Miguel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 119
