Ana içeriğe geç
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
Stuck on bootloader screen
stuck on bootloader screen. when I try to re-boot it just keeps coming back to boot screen
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try a Hard Reset.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
+ I like it when you talk like that. Ever thought of running for president?
tarafından
Yorum Ekle
Is the operating system stock Android that came with your phone?
If you installed a custom ROM, sometimes they can cause your phone to "boot loop" like that. Most of the time using a different kernel will solve the problem. That only applies if you're not using the stock operating system, though.
Puan 0
Yorum Ekle
If you rooted the phone go into the root menu: With celll off hold down button volume tap power on while holding down. Go to recovery do a wipe cache then go to advance and do a wipe cache in your selected rooted. MOST of the time this will repair the problem.
Puan 0
Yorum Ekle
step 1 turn off phone
step 2 count to three
step4 throw it as hard as u can at the ground
step5 pick up phone place gently in trash
step6 walk away.... lmao
Puan 0
Yorum Ekle
Yanıtını ekle
steve sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 4,408
