Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
iPhone resetting at 40% after installing a new battery
Hey, I recently installed a new battery in my 6s, but it now resets at anywhere between 30-50%, when it turns back on it reports either 1%, 10% or whatever % it was at last. I believe I installed it correctly (fullcharge 8hrs, full drain, full recharge, reset phone using power and home button). A low battery log is below. Any help is much appreciated. Thanks
Doug
{"bug_type":"120","os_version":"iPhone OS 13.6 (17G68)"}
Incident Identifier: 1FF01042-711D-43CE-9373-DBD4C8BB1404
CrashReporter Key: 3715515bb36c1781301c1f0507a7d67523f1a2d7
Date: 2020-08-01 06:41:45 +0100
OS Version: iPhone OS 13.6 (17G68)
runningboardd: daemon<com.apple.SpringBoard>28-55-3:FBSystemApp-PreventIdleSleep SystemIsActive == 255, held for 00:00:24
mediaserverd: com.apple.APEndpointManagerCarPlay.timed PreventUserIdleSystemSleep == 255, held for 00:00:10
locationd: com.apple.locationd.CLLocationAwarenessProvider.159052520(Active location session has begun) NoIdleSleepAssertion == 255, held for 00:00:06
apsd: com.apple.persistentconnection[apsd,121,APSDaemon-courierconnecttimer-PendingSimpleTimer(0x102763b70)] NoIdleSleepAssertion == 255, held for 00:00:02
apsd: com.apple.apsd-connectcouriers NoIdleSleepAssertion == 255, held for 00:00:02
nfcd: nfcd[pid:139,_NFSecureElementManagerSession,sessionID:0] PreventUserIdleSystemSleep == 255, held for 00:00:02
Screen Brightness: 0.247989
Hardware Model: N71AP
Awake Time: 00:00:00 (0)
Standby Time: 00:00:00 (0)
Partial Charge: 0
Capacity: 51
Voltage: 3486 mV
Voltage Droop Time: 40233984
Voltage Droop Transitions: 24
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The battery you purchased could be faulty. You will need to rule that out first. If it is not a faulty battery it will be a faulty component in the charging circuit most likely one of the charging IC’s called Tigris. This IC passes the battery information to the CPU and if faulty would give the symptoms you are facing.
This can be repaired by a reputable repairer but if it’s not the battery I would consider upgrading.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank you, I have got a replacement battery on the way, is there any way I can rule out the battery other than replacing it? I have reset the phone to factory settings and this has seemed to help. Doug
tarafından
No not really. You would need a device called a Tristar tester but these are expensive and sometimes not accurate.
tarafından
Yorum Ekle
Yanıtını ekle
Douglas Redfern sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 297
