Ana içeriğe geç
Released in March 2016. Model SM-G891A.
18 Soru Tümünü görüntüle
Camera and lens compatibilty with S7 EDGE
Hi, I have a broken rear camera lens broken and camers no longer focus and spotted.
There are very few parts fit ther and iFixt it doesn’t list parts for the S7 Active. So was wondering if the S7 EDGE camera(which by specs is the same) will fit the S7 ACTIVE. Samera for camera lens galss cover.
Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
From what I could find only the front camera is shared between the s7, s7 edge, and s7 active. When it comes to the back camera however, there’s three variants and you have to use the correct one or it won’t work. It should tell you who made the camera on the flex cable so you’ll need to disassemble the phone. You can find them here: https://www.mobilesentrix.com/replacemen...
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I am sure you might have found the solution. But this is for the people who are still struggling with same problem. S7 edge broken rare camera can be replace easily , the question Where to find the perfect compatible part. You can find the perfect options to fix your damaged camera at https://cellphoneandparts.com/search?q=S...
Puan 0
Yorum Ekle
Yanıtını ekle
Shadik09 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 129
