Will not move belt seems good and no slop
Mower stopped moving can get to go forward or backward lifted off ground and tried it only one tire moves when has weight on it it will not go
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Check the belt going to the rear housing. Make sure it's on and tight. Make sure the fluid level is full on the rear differential. Don't try to put it in gear on its side. It has fluid drive setup on the later models. That's why you can slowly at speed or punch it nice and smoothly. Look at your owner's manual or if you don't have it give me the model and I can see if I can find it online.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 25
