How do you replace the battery in a Harman Kardon Onyx Studio 4
How do you replace the battery in a Harman Kardon Onyx Studio 4 speaker?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I would be sure that your charger is actually charging properly first.
to gain access, slowly work front cover off all around using your thumb nails.
After cover is off, you will see screws to get in.
Bu yanıt yardımcı oldu mu?
How can you Know that the speaker properly charging? I mean the whiteb light is blinking like normal until until the speaker is supposedly charged an hour or two later and then the speaker works fine it's just not lasting as long as it used to. So should I replace the battery?
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 2,263
6 Yorum
Thank you! I will try another power cord I was able to take off the cover and find 5 plastic hex key screws Do you know what kind of battery is inside?
Darren Muci tarafından
This should be the battery you need.
Search this ebay:
Battery for Harman/Kardon Onyx studio 4 Replacement Harman/Kardon ICR22650 New
Rodney Miller tarafından
Also you might try a different wall socket for your charger.
Thank you very much, Mr. Miller; I appreciate your time and very helpful responses!
@darrenmuci You Sir, are very welcome.
1 tane daha yorum göster
