Ana içeriğe geç
The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
Yellow Vertical Line and how to resolve it
My MacBook Air's (early 2014) screen suddenly started to get one thin yellow vertical line in the middle of the screen; from top to bottom (Catalina).
  • When I did a screenshot, the line doesn't show
  • I did a hardware test and no issues found
  • PRAM and SMC reset doesn't resolve the issue
  • The line shows even on safe mode
  • Most unfortunate thing is that there is NO nearby Apple Authorized Service Provider to send for evaluation (plus its pandemic so it's not easy to travel far)
Hope someone can provide an answer on what possibly I can do.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
andrea bagani without seeing this line and only going by your description, this sounds like a Tab error. This is a fault where the ribbon cables from the LCD driver board to the LCD screen come loose. The only real option to fix this would be to replace the screen. There are companies out there that perform TAB repairs but those cost more than a new screen. MacBook Air 11" Early 2014 Display Assembly Replacement
To verify this, you can post some images of what the screen shows with your QUESTION. Adding images to an existing question
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
MacBook Air 11" Early 2014 Display Assembly Görseli
Kılavuz
Zorluk:
Orta
1 - 2 hours
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
andrea bagani sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 1,292
