Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
1196 Soru Tümünü görüntüle
Restart every 3 min After Battery replacement
I have a iPhone X that starts to freak me out.
Changed dock connector few Month ago, and it started to restart every 3 min after I pressed my code. Tried everything with new ports and so on, but in the end I swapped the motherboard and then it worked.
Now the same phone came back for battery replacement, since I know it's history I was really carefull and didn't even remove display. I just swapped battery and put together. Now it restarts every 3 min again.
Even if I disconnect everything (except the on off and display), phone still reboots.
Any suggestions? This makes me crazy
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
iPhone X and above are picky when it comes to charge port replacement as they only work with an OEM port. So if you’re using an aftermarket that could be why it was restarting to begin with. As far as why it stopped doing it when you swapped the board, I’m not sure why that fixed it.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
But it should work when connector is disconnected, right?
tarafından
@mexii no if I'm not mistaken. It needs a port connected in order to work
tarafından
Yorum Ekle
Yanıtını ekle
Johan M sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 80
