Ana içeriğe geç
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 Soru Tümünü görüntüle
Device won't turn on
My daughter came to ne with her DSi XL and said it will not turn on. Indeed when you press the button it flashes then turns off. It will turn on when a game is loading, but turns off immediately after. We have removed the battery, cleaned the contacts and fully charged it. There are no rattles in the case and everythign else seems to be in order. I am guessing it is the power board, but that is just a guess. has anyone else had this experience. Alos it has been dropped, but it had worked for a while after that.
Thanks
Bu iyi bir soru mu?
Puan 8
5 Yorum
I bought the dis 3years ago and it worked for couple of months
tarafından
My dsi xl doesn't turns on I'm just waiting for someone to sell me a charger
tarafından
My dsi xl has been broke since 2014 i think
tarafından
Have you charged the dsi?
tarafından
If i try to turn it on, nothing happens, it wont even flash
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Mark, if you are sure that your battery is charging and holding a charge you may want to check the LCD's and the cables, especially to the top screen. Those do have a tendency to break." If the top LCD ribbon cable is damaged or not connected properly the blue power light will turn on briefly and the bottom LCD screen will flash on very briefly when the power button is pressed. If the bottom thin LCD ribbon cable is damaged or not connected properly the blue power light will turn on briefly and the top LCD screen will flash on very briefly when the power button is pressed." Let us know what you find out. Good Luck
Bu yanıt yardımcı oldu mu?
Puan 8
8 Yorum:
Thanks! That makes sense. If the screen is at 90 degrees to the console I can push and hold the power button. It powers up and runs, but when I let go it quits. If I push it back one notch, it won't work at all. I have to leave on business, but when I get back I will take it apart and investigate your theory.
tarafından
Sounds good, have a safe trip. Let us know how it turns out.
tarafından
Thanks.... That got it. It was one of the connectors on the ribbon..... Lets see how long it last. Thanks for your help....
tarafından
Great job, good thing you got it working. All the best to you....:-)
tarafından
Hi, I have the exact same problem as above. How do I replace the ribbon?
tarafından
3 tane daha yorum göster
Yorum Ekle
The DSI Fixer Hey if you want your back buttons on your DSI to work all you have to do is blow on them with all your might.Then what you have to do is open it up and see if it works and boom it works again and if it doesn't work sorry. I am telling you this because it worked for me and it turned it on and made it work even better then before.
Puan 1
1 Yorum:
Wow, thanks! Didn't know that, will try!
tarafından
Yorum Ekle
Yanıtını ekle
Mark sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 19
Son 30 gün: 65
Her zaman: 55,891
