Ana içeriğe geç
The 2013 revamp of the desktop Mac series known as the Mac Pro.
117 Soru Tümünü görüntüle
Why my Mac Pro Cylinder Shuts down unexpectedly after few minutes (5)
Power on , ok, but few minutes shuts down
And I try to power on and nothing, only lights on ports like on video
If turn off, for a long time, turn on again, but some minutes turn off again.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Have you tried running the onboard diagnostics to see if an error pops?
After letting the system sit awhile if it runs longer being cold, restart your system and press the D key to enter. tell us what the error code is.
Reference: Mac startup key combinations
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Without an error code to aim us it will be hard to diagnose what has failed. The likely suspects are in order:
  • Power supply
  • Failing capacitor on logic board VRM power logic which supports the CPU
The cause can be as simple as a power surge/bad AC cycle coming from your power lines. I strongly recommend a good UPS. Your peripherals likewise need to be sharing this UPS or if at a distance using a good surge suppressor outlet strip or its own UPS. As an example my internet modem is on its own surge suppressor as its located a distance from my desk with an ethernet cable connecting to my trash can Mac Pro.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Aarao Marins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 948
