rear left brake light and blinker not working
my rear left brake light and blinker will not work. I have replace bulbs and fuses. Any idea on what to try next?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Angie Womack, check to see if you get power to your light assembly. I have had an assembly with a broken connector from the harness to the assembly, it had the same issues. Use a multimeter to check for current to your contacts.
UPDATE
or just a cheap simple testlight from corner hardware store.....;-))
Bu yanıt yardımcı oldu mu?
As a side note, you can also check potential (voltage) if you only have a playing old boring voltmeter :)
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 659
