Dirt in the lens body
I have dirt in between the lens. It looks like a plain piece of glass like a lens filter then the lens behind it. that where the dirt is
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@wakefieldkid this “looks like a plain piece of glass “ does not sound like a dirty lens. Remove the CCD sensor and see if the filter is still in place etc. Use the manual for the disassembly and if you absolutely do think you need to get into the lens. Again, from what you are describing it sounds more like an issue with the CCD.
Bu yanıt yardımcı oldu mu?
Make sure a clear ultraviolet filter is not screwed on the end of the lens. Often dust will be trapped between the filter and the lens. Look at the side of the filter (if there) and you should see markings indicating size ( example 72mm), brand, and type. These filters can become very tight, but never use any tool to try to remove. Grip with cloth or rubber tipped gloves to remove.
if no filter is screwed on the lens, and you see dust inside, that is a job for a camera repair specialist.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 289
