Ana içeriğe geç
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1226 Soru Tümünü görüntüle
Screen or Logic Board fault?
I have an iPhone 5c that was water damaged. The phone boots to home screen, however the screen does not respond to touch. There is a bit of corrosion on the screen connector. After I clean the corrosion, if the problem persists, is there a way to know if it is just the screen or a board level problem?
Thanks!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Clean the connector. If that doesn’t work, try a different display. If that doesn’t work, then try the original display with a different phone. If that doesn’t work, try factory reset (if you’re willing to)
If all fail, then it’s board-level.
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks for the help!
tarafından
Yorum Ekle
Yanıtını ekle
Caleb Topper sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 31
