Ana içeriğe geç
Mercedes-Benz W126, 1979-1992 yılları arasında Mercedes-Benz tarafından üretilen bir S-Serisi otomobil serisidir. W116 serisinin halefi olarak Eylül 1979'da piyasaya sürülen W126, Almanca "özel sınıf" anlamına gelen Sonderklasse'nin kısaltması olan bu prestijli unvanı resmi olarak taşıyan ikinci nesildir. W126, sedan modeli için başlangıçta sıralı altı silindirli, V8 ve turboşarjlı dizel motor seçenekleriyle sunuldu. Eylül 1981'de ise C126 2 kapılı coupé versiyonları tanıtıldı.
Can I fix keyfob with conductive glue
Have a keyfob that's not working. The 'open door' does not work. Close door and trunk buttons work.
Compared it to spare fob, and noticed two instances where tiny copper/gold plate circles were missing on the pcb board. Tested for continuity and failed. Good fob had continuity.
Wondering if carefully adding a drop of conductive glue in both areas would be a fix.
Photo has two arrows noting areas in question. The circled area represents the plate cover that exists on those two areas, on the good fob…(which are missing here)
Resim
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
**Answering for completion**
This keyfob is likely not repairable without loss of functionality, and conductive glue will not be enough. In this case the damage is quite deep and isn’t just minor surface level damage. You’ll likely need a new key.
Since you have a spare keyfob that’s 100% intact, you can often use that even on a Mercedes. If you didn’t have that you’d need to have a key made at a locksmith who is authorized by Mercedes to program a replacement.
You’ll need to know the model and year (chassis code helps too - think W204, for example) to find the steps to do this, as we do not know. The W126 is too old for a keyfob - this is at least a W2, C2 or R2 keyfob. For example this was used from the W202-W205, and various other models.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Sorry @nick but that is bull. Old post I know but had to comment. Those traces are repairable. Anybody competent in soldering could repair that with a couple of traces. I've done loads of boards with the same issues and doesn't take long at all. Writing off something that is easily repairable isn't why we're here.
tarafından
@strongbow Except this is a multi layer PCB. If the damage affects other traces it is shot.
It may be reparable but it may not be reliable or it will lose functions. Not worth the trouble, you’re better off replacing it. If it was my key I’d do the repairs and consider it my emergency spare.
tarafından
Surface damage from what looks like a screwdriver.
tarafından
@strongbow I would be very hesitant to trust a keyfob repaired with a wire. I’d have to make a new one and bring two.
If this was a Mercedes with the hidden backup key I may downgrade it to a key but on a keyless only Mercedes? NOPE.
tarafından
Yorum Ekle
Yanıtını ekle
Carl sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 692
