Ana içeriğe geç
Satellite radios, either portable or vehicle-mounted, allow you to listen to XM or Sirius satellite radio from anywhere on Earth.
23 Soru Tümünü görüntüle
Docking station works fine in one building,
Two buildings 20 yards apart. Two radios with docking stations work fine in bldg. A, neither one works in bldg. B. Both buildings have outdoor antenna with same view of the sky. LCD display shows station, artist and song title but no audio. Radio in bldg. B worked for about 5 years then quit. Replaced antenna and wiring in bldg. B still not working.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Hi @mcjimbo ,
Don't know the system that you're describing but are the docking stations fixed to the radio or are they fixed in the building and the radio can be removed so to speak?
If fixed in the building, just wondering if you can swap the docking stations to eliminate it as a possible cause.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Turns out the problem is with the power unit. It is a switching adapter that powers the speakers along with the radio function. Not sure exactly how it works but it can power the unit without powering the speakers. I have a new one on order, will update when it is received.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jimbo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 49
