What is the wifi card model?
wifi is not working, I tried to reinstall Os, still same. so if I want to change the wifi card what will be the wifi card model?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Here’s the guide to get to it: iMac Intel 21.5" EMC 3068 Airport/Bluetooth Card Replacement Presently this part is hard to find! iMac 21.5"/27" Airport/Bluetooth Card Apple P/N 661-07505 you’ll also need the heat transfer putty.
Are you sure that’s the problem? This is a custom part made by BroadCom for Apple.
I would do a bit more diagnostics before opening the system. Are you able to see the WiFi hardware under the System Report? What do you see in the menu when you press the Option key when you click on the WiFi icon on the menu? Take a snapshot of the grey area and past it here for us to see Adding images to an existing question.
If the system was already opened then it maybe the antenna plates got damaged as they are just behind the display glass.
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Kılavuz
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 90
