Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
26 Ekim 2018'de piyasaya sürüldü. A1984,A2105,A2106,A2108 Modelleri ile bilinir. GSM veya CDMA/eSIM , nano-SIM veya dual-SIM / 64, 128, veya 256 GB / Siyah, Beyaz , Mavi , Sarı , Mercan veya Kırmızı . ("iPhone 10 R." olarak telaffuz edilir.)
238 Soru Tümünü görüntüle
Not getting a display
So this customer came in and said he damaged his screen and it wont turn on but you can still tell the phones on because it will vibrate and you can hear siri, so we did a screen replacement but still no display, so we used a cracked screen that we use for testing and removed the back covering on it to shine a flashlight under it to see if we get any display, (forgot to mention that the backlight was not coming on with any of the screens we tried thats why we did the flashlight method which we have done before to get data off an iphone 6) so the phone turned on but you dont see the apple logo, you only see lines from when it was damaged before but then the phone turns on (vibrates) but u still get no display, the only picture u get is lines (from the flashlight we were using to give the device light) I tried a few other spare xr screens and im getting the same issue. The customer is only trying to get data off the phone but our issue is we arent having any luck getting a display. (we also connected it to a computer just to make sure it was on and you can hear the phone vibrate indicating its asking you to give permission to the laptop to access your phone) can anyone help me out please?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
hello Zach,
you have a broken circuit after a fall. Probably a short circuit in the video or touch lines. You need a meter and some knowledge. Measure the data and power lines in the video circuits, you should repair the damaged capacitor fairly quickly. If the lines are without any noticeable short circuits, turn your attention to the energy management in the video circuits and its inductor - fall damage also occurs here. A fairly easy to diagnose fault. You should be able to fix it in about 10-15 minutes.
  • regards,
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Zach Mentz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 136
