Samsung UN40H6203AFXZA 40” LED TV – no backlight
I was watching TV last night, and the picture suddenly went black but the audio remained working. The “flashlight test” shows the image IS on the screen – so I assume backlight is not working. Why?
I took off back panel to have a look. I unplugged connection between power board and main board and turned the TV on – the backlights did NOT light. I powered down and then reconnected the main board.
See images below for boards. The power connector going to the LED strips has the pins layout labeled as shown below, with voltages I measured:
Pin label Volts
1 D1+ 209
2 D2+ 202
3 D3+ 192
4 NC 0 (no connection)
5 D1- 202
6 D2- 192
7 D3- 0
With no voltage on pin 7, does that indicate the problem is with the power board, or the LED strips? How does one differentiate/correctly diagnose between these two potential causes?
Thank you,
Kurt
Bu iyi bir soru mu?
