Battery does not charging after replacement
I bought a new battery from ifixit , replace it everything work. I follow the recommendation that drains the battery to 10% then charge it up. The problem is it not charging up. I can see the icon of the battery with the lightning which indicates that there is power go in but leave there for the whole night and it still 5% then the battery completely drained. Moreover, if I keep connecting to the charger it can run but it won’t charge. I check everything I can, nothing bend or loose.
Update (12/11/2020)
Update, I switched back to my old battery, and that battery charging up. The problem with that battery is it only lasts from 1-2 hours without any hard use just read ebook. Is it indicate that this problem because of the new battery?
Bu iyi bir soru mu?
