Ana içeriğe geç
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
211 Soru Tümünü görüntüle
Black screen, ring, no image on the screen, burning smell
Hi, I am trying to fix my iMac which stopped working. I opened it, when I press Power button all 4 green lights turn on, and one of the parts starts burning:
https://youtu.be/QY-B5TLIU9E
Is it something that can be fixed?
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You have a short within the logic board! The sparks are around a Via which is a connection between different layers.
At this point you’ll need to find someone with deep skills to fix this or just replace the logic board iMac Intel 21.5" EMC 2544 Logic Board Replacement
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks, I will probably do that.
tarafından
Yorum Ekle
@earmand all of those connections and points are part of your backlight circuitry. The component right next to it is C9712.
Disconnect your LCD and check to see if that makes a difference. You also want to consider posting some really good pictures of your logic board with your question. Maybe we can find something obvious. Adding images to an existing question
Puan 0
Yorum Ekle
Yanıtını ekle
Efim Armand sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 153
