Ana içeriğe geç
Canon Pixma TS3122 wireless printer
My printer head is stuck to the right and won't move
The printer head won't move I am trying to put ink and my printer but when I open it the header is stuck to the right I cannot manually move it and it keeps flashing error code p02 and then I turn it off and turn it back on and it changes to error code e04 is there anyway I can fix this on my own?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
1 Yorum
My printer cartridges are stuck to left
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
A few things to check.
1 Be sure nothing is blocking it’s path (eg all ink cartridge locks are fully in place)
2 Try unplugging the device and plugging it back in, sometimes the bootup sequence will move the carriage before the errors
3 Try running a test print, again that can sometimes work to start moving the carriage.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
My own is not moving it show error code p70 that's d code it show then orange light
tarafından
I have turn it off for 10 minutes and turn it back still the cartridge head is not moving
tarafından
As soon as I turn the printer on it goes into "unable to init.48 so the print head won't move. All functions have stopped. I checked all the wiring but can't find anything. How do i replace the print head if I can't move it to the left. Thankyou for any help.
Tom tomluikart@att.net
tarafından
Yorum Ekle
When I moved the print cartridges manually by gently pulling on the tape, I found a really gunky mess under where the black cartridge rested! Looks like the cartridge must have leaked and it was thick black gunk. Lots of cotton swabs, rubbing alcohol, and a new print cartridge and it all worked again! I also cleaned the metal rod that the cartridges slide on.
Puan 1
Yorum Ekle
your printer must be running. then open the front and lift the rest and it moved to the middle. the printer must be running. i just did it all.
Puan 0
Yorum Ekle
How to fix a printer head that is jam
Puan 0
Yorum Ekle
Yanıtını ekle
Nini Irene sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 154
Her zaman: 16,825
