Replacing JUST the keyboard of the 16" MacBook Pro
With Apple switching back to the keyboard mechanism used in the 2015 Macbook Pro’s, I figured it might again be possible to replace the keyboard without replacing the entire top case. I have a Macbook Pro 16” with a defective arrow key, and sourced a new keyboard on Aliexpress for $30.
I took it apart, carefully removed the keyboard backlight (there’s a flex cable covering the ESC key area that needs to be disconnected first) and removed all visible screws - 20 or so. The rest of the keyboard is held in place with rivets, just like the 2015’s. I pulled out the old keyboard (using pliers), and then tried removing the left-over rivets. However.. That doesn’t appear to work: removing the rivets does not leave holes where you can then screw new screws in. Instead the rivets simply break off.
Thus I simply put the new keyboard in place, and used a dab of superglue on every rivet. To keep the keyboard pressed down I needed something heavy that wouldn’t cover too much of the keyboard, and settled on AA batteries - see the attached picture. I’ll assemble the Macbook again tomorrow when the glue is fully dry and report the results.
Update (12/30/2020)
I put it back together today and it works perfectly. So this post is just for anybody on Google who wants to know if it’s doable to replace just the keyboard on the 16” Macbook Pro - yes it is.
Bu iyi bir soru mu?
4 Yorum
Super Glue has its limits! Over time I'm sure some areas of your keyboard will feel spongy as the spots become loose.
Dan tarafından
Do the left over rivots need to be removed, or can I keep let them be? Has the super glue held up?
Alexandru tarafından
Hey, wondering how this is holding up long term. I got the same issue here. I tired ordering screws online, but haven't had any luck. Ones I got were too small. thinking of just gluing it at this point.
RocketBunnyBoy03 tarafından
Performed this repair some months ago on a 2019 model. I did not remove the rivets entirely, but did smooth out and shorten them somewhat with a Dremel. They were quite pointy after ripping off the rivet heads.
The glue is still holding up, and hopefully will for at least another two to three years.
Patrick Peer tarafından
