Ana içeriğe geç
Repair guides and information for the Nintendo Switch Joy-Con controllers.
167 Soru Tümünü görüntüle
Why don't my S series buttons work?
My S series buttons on my right joycon aren’t sensed by the controller, but the Sync button and the Player LEDs still work. Worryingly, when I take it apart, the buttons do work. It only fails when the joycons are assembled and the ribbon cable is bent to fit into the case.
Help me iFixit, you’re my only hope.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hello,
It’s definitely wierd but is that really the ribbon cable that cause the issue ? it could also be due to a contact between two parts that shouldent be connected.
Mayby try to look at a case replacement tutorial to see if you put it back correctly.
Here’s an example :
Nintendo Switch Left Joy-Con Shell Replacement - iFixit Repair Guide
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I guess it is possible, but I've put it together just fine several times before this, and it would work just fine until recently. It also wasn't acting the same when disassembled as the one in the left joycon. I ended up buying a new board to replace it, and that works just fine now and has different colors of LEDs.
tarafından
Yorum Ekle
Yanıtını ekle
Rosetta sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 47
