Ana içeriğe geç
iPhone 11 turning off after screen replacement
I repaired an iPhone 11 it was a screen replacement and back glass replacement with the forward laser machine everything seemed to work fine but when the phone is on for a couple minutes the phone turns off and back on. After it randomly restarts it acts like normal until a couple minutes have passed it does it again. I’ve tried a different battery and even the original screen but it still does this. I’ve also disconnected the front speaker flex in case it was causing problems but it still does it. I put it into dfu mode and updated it successfully now its on a white screen that says attempting data recovery but it keeps turning off before it finishes any ideas on how to fix this power off problem.
Bu iyi bir soru mu?
Puan 2
1 Yorum
have you try updating the phone
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
In this case, the charging flex or the microphone/flashlight flex next to the camera might be damaged.
These contain sensors (prs0 and mic2) that cause the phone to restart after some time if no valid signal is received.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I had the same problem with a iPhone 11
tried everything
last resort is changing out the battery
Puan 0
Yorum Ekle
If the screen was replaced without disconnecting the battery it will short circuit your phone therefore once that is done even a new battery will not fix it it's happen to me twice once when I paid for it to be fixed and second time I did it was trying to move to fast
Puan 0
1 Yorum:
Any fox for this ??
tarafından
Yorum Ekle
Yanıtını ekle
Daniel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 104
Son 30 gün: 459
Her zaman: 5,874
