Front camera not working after changing battery
Hi,
I just completed a battery exchange on my iPhone 6S following the instructions here and it has gone well except for one thing. The front camera is no longer working. I did not disconnect the screen when doing the battery switch but had is connected with rubber bands to a can of beans. So, even though the screen did not bend more than 90 degrees, I guess some connections might have experienced some strain during the process.
Before I go through the hazzle of opening the phone again. Is there anything I can check from the outside? I have confirmed the proximity sensor is still working because the screen turns off when I hold my hand close to it so I simply wonder:
- Is there anything else I can check before prying it open again?
- Is it possible that the camera connector could have unplugged itsel for is it more likely that I have broken it?
Thanks in advance for any advice.
Bu iyi bir soru mu?
1 Yorum
Thank you for the advice. I will get on reopening the phone and cross my fingers it just disconnected.
Johan Lantz tarafından
