Do iPhone battery stats still display?
Do you still see battery stats after replacing the OE battery with the iFixIt battery?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I have been running an iFixit battery in my iPhone 8 I rebuilt last year (custom blue housing :D ). Battery percentage works, battery usage stats work, battery health seems to report proper maximum capacity, performance capability, and it still lets me use optimized battery charging. I have also replaced several batteries on 8 and 8 Plus models with other third party ones and on every one I have replaced, battery health stats and percentages still work totally fine. You should be good to go.
Bu yanıt yardımcı oldu mu?
You should still get battery percentage and max capacity info after you change the battery with an iFixit kit. Just be very careful when disconnecting the battery. Sometimes people knock off battery gas gauge which results in constant restarting and battery percentage remaining at 1% no matter how long you charge it.
now that I have found out I have knocked the gas gauge bit off - any guides as to how to repair?
@hardijs That's something you should really leave to a specialist. You need thousands of dollars in tooling and a lot of practice. Luckily there are specialists that can fix it. The top 3 I recommend are iPad Rehab, STS Telecom, and Rossman Repair. All of which have youtube channels you can check out.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 93
