iMac doesn't turn on
Hi all!
My iMac doesn’t turn on normally. The thing is that it works properly when its up and running. The only way to turn it on is reseting the SMC:
- Unplug all USB devices and the computer.
- Wait for 15 seconds.
- Plug the Mac back in and wait another 5 secs.
- Turn on your Mac.
I have replaced the power supply and the CR2032 PRAM battery… and still having the same problem. ¿Is that a logic board issue? Any help appreciated.
Thank you!
Bu iyi bir soru mu?
I would run the onboard diagnostics. Restart your system and press the D key to enter.
Reference: Mac startup key combinations did you get any errors?
Dan tarafından
Thanks Dan but no luck. The hardware test went fine... 'no trouble found'.
Pablo tarafından
