Presser foot does not lower
Presser foot does not lower and when raising foot, lever feels tight. Have oiled part. Does not help. If left long enough, about 5 minutes, presser foot will lower.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Don’t know about this machine but here’s the presser foot section from the service manual for a Bernini 930 that may help you to see what’s going on.
To check if the adjustment on your machine is correct you may have to improvise as I cannot find the “feeler gauge” mentioned in the manual but maybe you can place a 7.5mm object under the presser foot as described.
Sorry that I can’t be of more help on this.
Bu yanıt yardımcı oldu mu?
I will try suggestions and let you know in a few days. The machine is my Mom’s. Thank you!
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 226
Hi,
What is the make and model number of the sewing machine?
jayeff tarafından
Sorry! That info would have been helpful. It’s a Bernini Record 930 Electronic. Thanks!
Nancy Spooner tarafından
Bernina Record 930 Electronic
That seems quite a niche market. On the bottom of the pedal there should be a type number lik 'Type 213' or 'Type 290'. Which one do you have?
gmantunt tarafından
