Ana içeriğe geç
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112 Soru Tümünü görüntüle
Why is my touchscreen unresponsive but it's detecting touch.
For some reason my new tablet i got off ebay, stopped working the day after i got it. The touchscreen was completely unresponsive but the screen was detecting touch? Please help i’m in a state of panic.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Your question is vague and oxymoronic (no offence in using that word).
You state that the digitizer is not responding to touch but then that it is? If you mean you are pressing the screen so hard as to put pressure on the LCD, then stop. That’s too much pressure.
Purchasing from eBay has a “buyer beware” clause right? Which means, either this is a defective used product or a mis-labelled defective new product. If you wish to repair it, use the teardown guide to take it apart and purchase a replacement screen to test it on.
The digitizer which registers the touch could be the issue. Also be aware, a non-touch responding tablet doesn’t necessarily mean a bad digitizer, but can also mean a bad board issue. The digitizer is clearly glued to the front glass so it will take some time to replace the digitizer. Alternatively, you can replace the entire “display assembly” which includes the glass, digitizer, LCD, front chassis.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Altoid sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 43
